HYSTER S50E S/N D002D02421
WE NEED TO INSTALL A BACK UP ALARM ON A OLD HYSTER MONOTROL TRANSMISSION. WERE CAN WE FIND THE REVERSE PRESSURE PORT? HYSTER S50E S/N D002D2421
  • Posted 12 Apr 2013 05:28
  • By VIPER
  • joined 9 Feb'11 - 24 messages
  • FLORIDA, United States
There used to be a kit with a different pedal assy that had a switch and wiring harness built in, to do it correctly. Sorry dont have a part number but a Hyster dealer with a good parts guy should be able to get one for you.
  • Posted 13 Apr 2013 04:31
  • By bigGlittlestar
  • joined 12 Aug'08 - 139 messages
  • United States
Don't think it matters, is it a monotrol? If it is, there are 3 pressure hoses on the pedal, you might be able to tie into. One of them is reverse pressure port, you might be able to use a brake line to extend and install a switch at the trany end.
  • Posted 12 Apr 2013 19:06
  • By 7777
Putting a pressure switch on the reverse port will only activate the switch when there's pressure present but not when the inching circuit is activated. Don't back up alarms need to be wired so that the beeper sounds when reverse is selected, not only when the truck is moving?
  • Posted 12 Apr 2013 09:28
  • By bbforks
Muncie, IN, United States
