Fault code 47 Mitsubishi FBC20N-AC
I need to know the meaning of the code 47 in Mitsubishi FBC20N-AC series A4BC230216
Thanks
  • Posted 27 Mar 2013 01:35
  • By Ropalman
  • joined 21 Apr'12 - 11 messages
  • Concepcion, Chile
"If it wasn't difficult, it wouldn't be fun"
Problem is in the Pump Motor Circuit
Here are some possible causes for this code 47
-Faulty contact or wire breakage of pump motor cable
-faulty pump motor, faulty contact or wire breakage of pump
inverter connector
-faulty contact of DSP flat cable in pump inverter
-wire breakage of main harness
-faulty power supply card of logic unit
-faulty DSP card of pump inverter
-faulty pump inverter, when restarting after motor shorted
i would check all your harness connections at the truck manager card (logics card)
if no problem found there remove the cover on the motor control and check the ribbon cable to the dsp card.
also would check the controller itself at the UVW connections
  • Posted 28 Mar 2013 23:30
  • Modified 28 Mar 2013 23:32 by poster
rpalma @ tattersall.cl
Thanks
  • Posted 28 Mar 2013 07:36
  • By Ropalman
  • Concepcion, Chile
[email address removed]
Thanks
  • Posted 28 Mar 2013 07:35
  • By Ropalman
  • Concepcion, Chile
e-mail?
  • Posted 27 Mar 2013 07:33
  • By LTRM
  • joined 26 Jan'12 - 161 messages
  • Illinois, United States
Nagano NUZ090D
Taylor TT300
USD98,500
