Starter
I walked in on a competitor giving a customer a quote on his forklift. He told the owner that the starter cone had broken off and got into the hydraulic pump and destroyed it. He showed the owner that fluid ran out when he removed the starter and that is what led him to that diagnosis. It has the GM engine in it. Does this truck have a wet clutch? The owner offered it to me at $800. Does the diagnosis fit? Is it worth it? It has about 4500 hours on it and newer tires. Let me know, thanks, Jim ser. # A187V13902R
  • Posted 22 Mar 2013 07:25
  • By jim_v
  • joined 26 Aug'08 - 61 messages
  • Michigan, United States
Serial number ending in R is a 1994 model
Starter # 335867 and 353221 cross to be the same Delco starter. 388040 is for the Mazda engine trucks.
  • Posted 22 Mar 2013 22:31
best i can tell from the serial number of the truck A187V range
they say either a 388040 or 326875 depending on production dates (engine serial numbers).
the reman available is 3003784R
i ran your truck serial number through thier db and it comes up invalid number so it may be an older truck not in thier db (pre 2000) or u got some numbers wrong.
  • Posted 22 Mar 2013 20:27
  • Modified 22 Mar 2013 20:32 by poster
is either going to be a 353221(early Production) or a 355867(late production)
  • Posted 22 Mar 2013 09:50
  • By kevin_t
What size cubic inch is the engine,is it a 153??
  • Posted 22 Mar 2013 09:46
  • Modified 22 Mar 2013 09:47 by poster
  • By kevin_t
I don't have the starter number for the 50. The ones I work on are 80's with the GM V-6.
  • Posted 22 Mar 2013 09:35
  • By bbforks
I would like to fix and sell the unit. I had a feeling that the rookie mechanic made an error. It does have the pump on the trans. I want to install a new starter and fill the housing and drive away. Do you know the starter number? Thanks, Jim
  • Posted 22 Mar 2013 08:46
  • By jim_v
The XL series lifts I work on (8000lb) have a wet bellhousing. Take the floorboard off & see if the hydraulic pump is on top of the trans, if it is, then the bellhousing is wet.
The hyd. system has a filter in the tank- I would doubt that the starter remnants got into the hyd pump. What are the symptoms of the hyd system?
I personally have had starter noses break off in the bellhousing. Cleaning out the bellhousing, flushing the hyd oil & replacing the hyd filter was all that was needed- the lift had no lingering symptoms- that was about 1000 hours ago
What would you do with the lift- fix & resell or fix & use?
  • Posted 22 Mar 2013 08:21
  • By bbforks
Toyota 02-2TD20
Crown RD572513TT6860R
