Hyster 2.5Ft slow hydraulics
Hi I have a Hyster 2.5Ft serial No L177B09209D
truck only covered 6000 hours
truck has fingertip controls and the lift/lower is very slow especially on free lift cylinder
the main cylinders dont seem too bad
I checked in settings and lift speed is set to 10, I am presuming that lower is the same as there doesnt seem to be seperate settings for lift /lower
lift isnt as much of a problem as you can rev engine to make it go
when oil is warm it improves a bit and when there is a load on it is better, but not as fast as i would expect.
without load it is about 5 mins to drop free lift cyl
Maybe check valve sticking but not had a look yet
any one have any experience of this problem?
  • Posted 13 Mar 2013 05:50
  • By ian_h
  • joined 11 Sep'08 - 149 messages
  • United Kingdom
Try to check the wear on the joints of the lever.
A lot of those levers wear on the joints and then it starts going down more slowly.
When it has wear on the joints replace it and calibrate the new lever.
  • Posted 18 Mar 2013 05:36
  • By Robb
  • joined 16 Dec'08 - 38 messages
  • Classified, Netherlands
robin4567 at outlook dot com
no problem bbforks,
i actually do stand corrected
your right... the valve in the piston is a flow valve that controls fluid flow in the cylinder and aids in the sequencing of the cylinders. The velocity fuse valve is actually on most systems inside the fitting generally on the outside cylinder right hand side or the first cylinder for the inner channels.
I had to go back and read up on my hydraulics theory of operation on these systems.
Its what happens when you get old, brain goes first hehe ;o)
thanks
  • Posted 14 Mar 2013 08:17
thanks for all the input.
just been working on site today and speaking to driver who told me that if you push lever realy hard mast goes down faster!
sure enough when i tried this - full speed
swapped over joysticks between sideshift and lift/lower.
Now lift/lower works perfect.
the joystick that was on lift works sideshift at acceptable speed, possibly starting to fail internally?
anyway I left the levers in swapped over position and all drivers are now happy!!
Just goes to show, sometimes dont think or look too hard at problems, try simple things first
  • Posted 14 Mar 2013 07:37
  • By ian_h
  • United Kingdom
No disrespect swoop-I'm just not sure we're talking about the same valve. There's a valve in the outlet port ( the velocity fuse ), the other valve in the bottom of the ram itself (inside the cylinder). You are correct that the velocity fuse is to limit downward travel of the carriage in case of a hyd line failure. The valve inside the cylinder is the differential valve- it's purpose is to equalize the pressures of the cyl below & above the lower packing assy ( this valve is only used in differential type cylinders).
  • Posted 14 Mar 2013 07:08
  • Modified 14 Mar 2013 07:12 by poster
  • By bbforks
it is a check valve designed to keep the fluid from exiting from the cylinder too quickly in the case of a line rupture. Some mfg's call it a velocity fuse, others call it a safety down valve, cat calls it a check valve.
It may serve a dual purpose as an equalizing valve but its original intent is to restrict flow in the case of a line break/rupture. (a safety check valve)
Unfortunately when this valve malfunctions it causes raise/lower issues and mast sequencing issues as well.
so whatever it is called by the mfg it has been an issue in many cases that I've seen such as this.
  • Posted 14 Mar 2013 00:44
The valve in these newer displacement type hoist cyl's isn't technically a safety valve ( like the 10% limit valve in the inlet port). but rather a valve to keep both sides of the cyl (under ram & between ram & shell) under the same pressure- kinda like the lock valve in the tilt circuit- keeps both sides of the tilt cyl's pressure equal
  • Posted 13 Mar 2013 23:07
  • By bbforks
sounds to me like a safety valve in your cylinder malfunctioning.
I've seen this symptom happen alot in different masts and it generally winds up being a safety valve either sticking or blown apart.
most cylinders in masts today are fluid displacement type and they install a safety valve in the piston at the base of the piston.
  • Posted 13 Mar 2013 22:31
you already did the calibration mini levers
you can adjust the valves manually
  • Posted 13 Mar 2013 10:07
  • By forklift_brazil
  • joined 15 Nov'12 - 108 messages
  • rio de janeiro, Brazil
tecmanuais@yahoo.com.br
skype:hyster.brasil
Has someone shimmed the carriage rollers too tight. Also you can manually adjust the valve
  • Posted 13 Mar 2013 09:21
  • By grubbymits
  • joined 25 Jan'09 - 49 messages
  • scotland, United Kingdom
Is the upright a triple stage? If so- how are do the secondary cyl's react to input ( up & down) once the primary cyl is fully extended? I assume the other hyd. functions are acting normally.
If the other functions & the secondary cyl's are acting normally, I'd suspect the valving inside the primary cyl. It seems when that valve goes bad it can have quite alot of different symptoms.
  • Posted 13 Mar 2013 06:06
  • By bbforks
edition #1240 - 24 July 2025
CeMAT Australia 2025 has been underway in Sydney this week, wrapping up today, with the main topics coming out of the event proving to be the very predictable automation and sustainability... Continue reading
Hawker Powersource, Inc.
On the 88th day of the year, 29 March in a non-leap year and March 28th in a leap year, World Piano Day (also known as Piano Day) is celebrated. This date was chosen because a standard piano features 88 keys.
Simon Manasseh Simon Manasseh
VP business development for Europe, Noblelift Intelligent Equipment Co
Regional business manager, Doosan Bobcat Material Handling
President and CEO Swisslog Americas, Swisslog
Vice president, Newgentech Material Handling India
