AC input on charger
I have a Tennant 2200 36v charger. I need to change input from 408v to 220v 1ph. I moved board inside to 220v.now charger turns on for about 5 seconds then shuts down.The manual was not with charger.There are six nuts holding board in.2 are obvious but not sure about others.I tried several different places. Is there something else I need to switch for 220? Any help would be greatly appreciated.
  • Posted 27 Feb 2013 12:42
  • By jim_k
  • joined 28 Aug'08 - 21 messages
there is also a jumper that needed to be moved on the control transformer (small, electrically attached to the line contactor's [24v] coil) a/c input line. maybe too late now. more than likely still will work if you fix the wires
  • Posted 27 Feb 2013 22:04
Find the dealer or manufacturer and they should send you the configuration free
  • Posted 27 Feb 2013 20:15
  • By 7777
