Hi , i have a Steinbock PE 25 AC truck , the same as Jungheinrich , i wl set parameters in the display but the factory code 1234 does not work... how can i find the right code for check the service menu? Does i need Judith? i hope not
Steinbock
PE25 MP /440 DZ
275342
Can you please give me serial of that machine I need to know what you have of display?
Canbox and cables that use Jung,
Hi , i think also , do you know what cable i need , only serial connector cable to laptop or interface/canbox?
Yes you need Judit because someone was change factory code and now only you can see this code with Judit.I will check again this info but i was sure 99%.
