Stuck in reverse
Help please,my V50D forklift,s/n 3ECO399 is stuck in reverse.I checked switch,wire harness,selnoid packs,cleaned valves and it is still stuck in reverse,in reverse-reverse,in neutral-reverse,forward-locks up like both gears are engaged. Have not been able to locate a shop manual yet and out of idea's what to do next. Any help/ideas? Thanks big ox
  • Posted 23 Feb 2013 15:19
  • By bigox
  • joined 23 Feb'13 - 4 messages
  • Michigan, United States
Hello, I also have a problem with a drive on my forklift Cat V40D. but I was wondering how you fix the problem.
  • Posted 25 Dec 2016 09:06
  • By gojko_b
  • joined 25 Dec'16 - 1 message
  • Croatia, Croatia
It would seem you are correct sir,It is in reverse with direction switch unhooked,and fluid drained. Thanks again for the input and help from you and every one else. BigOx
  • Posted 18 Mar 2013 13:51
  • By bigox
I think you're at the point where you need to jack the front wheels off the ground, drain the transmission, and start it up. The torque convertor will still have oil in it but the transmission pressure will be zero. If it still goes backwards, the clutch is jammed and the transmission needs to come out. It is a 15 minute test and a positive diagnosis.
  • Posted 28 Feb 2013 22:15
Yes I reversed the spools and no change.I pulled the two plugs on the valve body located to the right of the pilot valves and removed the spools and springs and every thing looked good too me.reassembled everything and still have the same problem. I,ll try to list my email again. Thanks for your help and info.
  • Posted 28 Feb 2013 12:50
  • By bigox
I can send you a diagram of the f and r spool valves. Did you take the solenoids off, pull the spools out, and reverse them as a test? You will need to list your email address in your user info box.
  • Posted 24 Feb 2013 06:29
I have reversed the pilot control valves and no change.I,ll try the neutral test and see what happens. not sure about location of control valves that would need inspecting,still looking for a service books for this s/n machine. Anybody willing to share a diagram? s/n 3ECO399 Cat.V50D Thanks
  • Posted 24 Feb 2013 04:17
  • By bigox
try swapping the fwd and rev solenoids and see if the problem reverses itself. If it does then you have a bad solenoid valve. If not then the problem is internal to the transmission control valve. One of the valves in the control valve is stuck or a broken spring or something. You will have to physcially remove these and inspect them for sticking, dirt, or broken parts or wear.
you can also just remove the wires from the solenoids and it should just sit there in neutral, if not then like i said, start in the control valve and go from there.
It is possible there is an internal clutch issue but i would check the things i mentioned first before tearing the tranny apart.
  • Posted 24 Feb 2013 02:54
  • Modified 24 Feb 2013 02:55 by poster
It sure sounds like your reverse clutch discs are warped or broken and jammed. Drain the transmission fluid and if it still wants to go backwards, it's bad news.
  • Posted 23 Feb 2013 22:10
Muncie, IN, United States
UN Forklift FGL35T
TCM FD80Z7
TCM FD80Z7 1990
UN Forklift FGL35T
TCM FD80Z7
TCM FD80Z7 1990
