Hyster S120XL slow travel
Recently removed and reinstalled motor for unrelated transmissions problems. Put fresh transmission fluid in and now when going into forward or reverse, you have to rev the motor very high to get unit to move. Once you travel for 50 yds or so, will drive fine. Any ideas out there???
Thanks in advance!!!
David
  • Posted 9 Feb 2013 00:29
  • By 1sharpdog
  • joined 20 Apr'12 - 220 messages
David Sharp
Have a Great day and thanks for all the great advice! sharpforklift@gmail.com
Will try that and post results. Thanks!!!!!!!!!!!!!!!!!!!!
  • Posted 12 Feb 2013 08:37
  • By 1sharpdog
David Sharp
To answer your question on why it work work normally after a few minutes- I believe that if the inching valve is just slightly mis-adjusted, that after a few minutes the pressure build- up overcomes the slight pressure release. I have had the same symptom on a H80XL- happened out of the blue. Adjusted the inching linkage & symptom went away
  • Posted 11 Feb 2013 23:42
  • By bbforks
yup, sounds like the inching circuit is still enguaged while the brake pedal is released. I'd check the adjustment for sure.
Keep in mind it is not designed to run for long periods like this so if it is ran too long with the clutches slipping it can wear out the clutch packs quickly. So i wouldnt lollygag around too long before i went back to check it. ;o)
Good luck
  • Posted 10 Feb 2013 22:23
Thanks for the advice. Haven't been back to customer to troubleshoot, but if it were out of adjustment, why will it travel normally after reving up for a couple of minutes. Just a question, they are very ****, as most customers are. LOL
  • Posted 10 Feb 2013 09:21
  • By 1sharpdog
David Sharp
Sounds like the inching pedal is out of adjustment.
  • Posted 9 Feb 2013 05:52
  • By bigGlittlestar
  • joined 12 Aug'08 - 139 messages
  • United States
Aichi SR18A
Kalmar-Ac P100CXD
Muncie, IN, United States
Aichi SR18A
Kalmar-Ac P100CXD
Deborah Baker Deborah Baker
