code 61
6BRU18 unit will give a fault code 61 every couple weeks. Checked all steering system. Wiring ohms fine to each componet.
Any other suggestions? Thanks
  • Posted 8 Feb 2013 01:14
  • By phil_r
  • joined 9 Apr'10 - 21 messages
  • Illinois, United States
most likely going to be the steer motor brushes
  • Posted 14 Feb 2013 13:18
  • By fixnproblems
  • joined 19 Jan'13 - 66 messages
Have you pulled the right side cover while the code is present? The steer controller is behind it and the leds can point you in a direction. You may also want to check the coupling between the steer wheel and the steer tach. If that is ok check the steer tach itself.
  • Posted 8 Feb 2013 07:45
  • Modified 8 Feb 2013 07:47 by poster
  • By rogeriwt
Deborah Baker Deborah Baker
Muncie, IN, United States
