Jungheinrich Etv 25 G 1999 error 42 Brake coil?
Hi , anyone know what this error mean ? It is a 1999 reach truck , no steer ,drive and hydraulic
  • Posted 4 Feb 2013 00:40
  • By gc_d
  • Zuid-Holland, Netherlands
Regards gc_d
fine you solve it friend
Regards
  • Posted 12 Feb 2013 07:05
  • By nacsand_n
  • joined 20 Sep'09 - 716 messages
  • Madrid, Spain
Hi
Thanks friends for the info you have send to me , i found the problem , logic card steer and brake defective , but the led are green on the print ! I have replace them and set the cable of the brake coil exactly correct and teach in teh brake pot so it is fixed. Regards
  • Posted 12 Feb 2013 06:55
  • By gc_d
Regards gc_d
Hi all , thanks for all the info , i will check this and i hope i can fix it. i write the problem as i found it
  • Posted 5 Feb 2013 04:27
  • By gc_d
Regards gc_d
I once worked on an ETV reach, where it stated brake fault. I vaguely remember being able to reset brake pot?? I think. Is there this option on this truck?
  • Posted 5 Feb 2013 03:09
  • By elektrodrive
enquiries@elektrodrive.co.uk
That's the one nacsand n, I remember it now - it was basically simple plug & play, just needed to fix the contactor down securely, I was sceptical at first but the mod kit sorted out the problems on my ETV trucks.
  • Posted 5 Feb 2013 01:11
  • By Forkingabout
  • england, United Kingdom
First you have to check the brake pads adjust, because the displacement of steel brake cable must be between 4mm (min) - 6mm (max).
Forkingabout is right, there is a service message about this fault. It's neccesary to install a small contactor and do a small wire modification.
Check your mail
Regards
  • Posted 4 Feb 2013 07:30
  • By nacsand_n
  • Madrid, Spain
Can you write serial of truck.Is it good your brake coil on the truck? Did you check wiring for brake?
  • Posted 4 Feb 2013 05:02
  • By nemanja_k
  • serbia, Serbia
  • By nemanja_k
  • serbia, Serbia
I vaguely remember fitting a mod kit to some ETV reach trucks a few years ago due to a similar brake fault.
They where around the same age as the truck you have.
  • Posted 4 Feb 2013 04:46
  • By Forkingabout
