Toyota 7FBEF18 Error A5
The serial of this truck is 7FBEF20 15968
The problem we have is that we have had 2 similar Toyota trucks throw up these errors. We checked the brake switches (no brake pots). However in the case of 1 truck once you disconnect the battery and reconnect the fault clears, for hours or days in some cases. The other one also clears once the battery is disconnected and connected, however sometimes just clears if left standing.
Is there a problem that Toyota might be aware of? Or has anyone come across this issue? Any tips and suggestions would be appreciated.
Regards
  • Posted 2 Feb 2013 02:01
  • By elektrodrive
enquiries@elektrodrive.co.uk
Hi
Just an update.
The customer had bypassed the seat switch after informing him this was one of the suggestions. My only concern was that with the seat disconnected it always came up with an operator error of some sort, however Since then he has not complained. Its been 3 days so far without fail :)...then again sometimes it went weeks..we will have to wait and see.
Thank you for all the pointers and advice, much appreciated.
Regards
  • Posted 7 Feb 2013 02:34
  • By elektrodrive
HI will do all checks on Monday, However with the seat switch disconnected it comes up with a different error cannot recall will make a note on Monday.
  • Posted 3 Feb 2013 04:47
  • By elektrodrive
Hi mate,
A5 indicates a seat switch abnormality. check wires from connections CN101-5 / CN101-16 in CPU board. Also can check if is OK through display in monitor mode.
Check your mail
Regards
  • Posted 2 Feb 2013 06:54
  • By nacsand_n
  • joined 20 Sep'09 - 716 messages
  • Madrid, Spain
Thanks will check monday. I am guessing the display comes apart easiliy?
  • Posted 2 Feb 2013 05:02
  • By elektrodrive
Hello
I once had problems like high in the dashboard of a lithium battery is weak.
Best regards, Laci
  • Posted 2 Feb 2013 03:08
  • By LACI
  • joined 24 May'09 - 195 messages
  • Serbia
Toyota 8FG25
Deborah Baker Deborah Baker
