Hyster J30XMT code -15 issue
I am looking for test procedure for a code -15 on a Hyster J30XMT S/N F160N01507U. We do not have a manual for this truck in our shop.
Thanks for the help.
  • Posted 1 Feb 2013 12:13
  • By RAFARMER
  • joined 17 Jan'12 - 153 messages
rafarmerjr@gmail.com
Minimum battery volts not present between P1 and NEG.
Check for battery volts between P1 and negative standoff. If battery volts are not present, check for a voltage drop between battery (+) and P1 and/or between battery (−) and negative standoff. P1 comes from the battery side of the key switch. Also check your fuses.
  • Posted 7 Feb 2013 01:14
  • By garland_m
  • joined 16 Oct'09 - 212 messages
  • Virginia, United States
If it is a three wheeler with SEMS controllers then you either have a battery problem ie voltage to low check for at least 1.95 v per cell or a controller that may be set to the incorrect voltage for your battery.
Regards Titus
  • Posted 1 Feb 2013 19:09
  • By Titus
  • joined 6 Jul'10 - 185 messages
