7fbmf20 power off
hi,
i have 7fbmf20 that the display is off and line contactor didnt work
i checked switch that is correct.can you help me?
Thanks
  • Posted 31 Jan 2013 19:07
  • By mohsen_d
  • joined 2 Dec'10 - 25 messages
  • tehran, Iran, Islamic Republic Of
Thanks for reply.
ok.cpu board has 5 v supply.voltage at wire for keyswitch is 15 v.
  • Posted 3 Feb 2013 06:08
  • By mohsen_d
Checked the switch? I am assuming supply to the keyswitch? Usually when you get nothing to the extent no thing on the display at all, its possible you have lost a supply feed either the Pos or Neg. Does your horn work?
  • Posted 2 Feb 2013 02:19
  • By elektrodrive
enquiries@elektrodrive.co.uk
hello
Check it out in the third - 48V connect the battery connector. This plug is in the middle, go through all controls.
Best regards, Laci
  • Posted 1 Feb 2013 02:54
  • By LACI
  • joined 24 May'09 - 195 messages
  • Serbia
SMV (Konecranes) 16-1200C
SMV (Konecranes) 4538CCX4
