Yale M# MSW040SEN24TE077 S#C820 ZAPI
Hello, Code AL06 when unit put into fwd/rev Code AL10 when hyd used. Zapi Contoller. Any ideas ??? e-mail me prenticelift at gmail dot com. Thanks
  • Posted 23 Jan 2013 03:38
  • By Prentice
Prentice,
It is not the volts as much as it is the amperage. The contactors are known to go bad on these units. The volt meter may read same voltage on both sides at static. The minute you try hydraulics or drive and everything drops on the controller side.
  • Posted 25 Jan 2013 06:41
  • By garland_m
  • joined 16 Oct'09 - 212 messages
  • Virginia, United States
Dear friend
please insert your email
  • Posted 24 Jan 2013 07:32
  • By makan_j
  • joined 14 Apr'11 - 17 messages
  • Tehran, Iran, Islamic Republic Of
Always go with the gut feeling....main contactor turns on. 25 v on Battery side 23 controller side- Replaced contact assembly. Good to go. Surprised 2 volts would make a difference.
  • Posted 23 Jan 2013 06:15
  • By Prentice
Deborah Baker Deborah Baker
Muncie, IN, United States
