Aisle-master no hydraulics or steering
I have an electric aislemaster 20se. The hydraulics and steering has stopped working. All fuses etc are ok. Checked contactor and is working and when i bridge the hydraulics work. Traced wiring back to the board and i have no negative coming from the board to the hyd contactor coil. Any ideas?
  • Posted 22 Jan 2013 04:20
  • By andrew_p
  • joined 7 Nov'12 - 23 messages
  • Co. Antrim, United Kingdom
What is your email ill send you the wiring diagram.
  • Posted 23 Jan 2013 19:35
  • By Leon_W
  • Tyne & Wear, United Kingdom
Hi we have ac drive and dc lift. We are getting the programmer today so hopefully will shed some light
cheers
  • Posted 23 Jan 2013 19:08
  • By andrew_p
Steering is actuated by the accelarator pedal. Have you got any fault lights flashing on either of the curtis control units. Have you got DC drive and DC lift, AC drive and DC lift or AC drive and AC lift. I f you have got DC drive and DC lift. Pin no. 10 on the drive controller feeds pin 10 on the Lift controller once the accelarator has been pressed. This will bring the pump motor in at a reduced speed for the steering.
You can also check the fault codes/history by plugging in a curtis programmer.
  • Posted 23 Jan 2013 18:49
  • Modified 23 Jan 2013 18:50 by poster
  • By Leon_W
Hi
Pressure switch is ok and truck is driving ok.
  • Posted 22 Jan 2013 22:36
  • By andrew_p
since your hydraulics and power steering do not energise i will assume you have no truck operation (drive) either?
i would also check your directional switch inputs and seatswitch circuits.
  • Posted 22 Jan 2013 22:14
Check the pressure switch on the main pressure line on the control valve.
  • Posted 22 Jan 2013 10:16
  • By danny_k
Combilift Ltd
Deborah Baker Deborah Baker
Muncie, IN, United States
