SC5200 With no brake input
Please Help me. Have this unit that does not recognize brake input. Can calibrate, and passes. Once I turn key on, and am asked to activate brake, immediately goes into fault. Swapped accel pot and same problem. Does anyone feel its the access one module?
  • Posted 20 Jan 2013 11:49
  • By 1sharpdog
  • joined 20 Apr'12 - 220 messages
David Sharp
Have a Great day and thanks for all the great advice! sharpforklift@gmail.com
Update to this menacing problem. Remove access 1 module and put on sister unit, passed and traveled. Also installed new brake switch, still ***. Guess my only other option is to ohm out harness. What do you guys think???
  • Posted 25 Jan 2013 10:50
  • By 1sharpdog
David Sharp
Dear ctech,
Thank you so much for your input. I did swap accel pot with brake pot, same problem. Yesterday would not accept brake pedal input, before I left, put on charger. Today customer used unit for about 2 hrs, doing same thing. Battery reading 37.5 VDC. ??????? Going there right now.
Sincerely,
David
  • Posted 25 Jan 2013 02:23
  • By 1sharpdog
David Sharp
The brake switch input also goes into the Access 1. On the 5200 the display is what drives the brakes. I would check there. Also check your brake pot voltage and resistance.
  • Posted 25 Jan 2013 00:48
  • By ctech
  • joined 29 Nov'12 - 11 messages
  • United States
Thanks for the input swoop. Thats another thing. This has been intermittent for about a week. Now it is hard down. Haven't changed wire position on switch. Any other ideas?
  • Posted 24 Jan 2013 23:43
  • By 1sharpdog
David Sharp
ya it sounds as if its working backwards to me.
check that switch and see if it has a NO and NC terminal. It may be possible it could of been wired backwards?
  • Posted 24 Jan 2013 21:12
Thanks Jplayer,
I did check brake switch and this is what is confusing me. I found that once that micro switch is actuated, that's when the wrench on console comes on, and will not travel, just tells me to press on brake pedal. Also another bit of info, while in calibration mode, after I push enter button to show pedal not depressed, will ask me to depress pedal, and push enter. That orange wrench comes on, but display shows calibration passed. WTF
  • Posted 24 Jan 2013 09:19
  • By 1sharpdog
David Sharp
you may want to test the brake switch and its related wiring, if it (the controller) passes the 'calibration' you speak of then i'll assume the controller brake input circuit 'in' the controller is operating ok.
  • Posted 21 Jan 2013 21:23
  • Modified 21 Jan 2013 21:24 by poster
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Email: jplayer@liftone.net
Terberg YT223
Taylor TT300
Muncie, IN, United States
