1998 Hyster J40XMT 3 wheel, '5 start switch not closed'
hydraulic works but not drive and show this error code. where is the start switch?
  • Posted 14 Jan 2013 11:03
  • By li_w
  • joined 16 Nov'09 - 49 messages
thanks for your help. i do checked parking brake, brake and seat switches. and all the fuses i can find. but don't see any problem.
  • Posted 30 Jan 2013 23:21
  • By li_w
check park brake switch and related wiring, if parkbrake switch is malfunctioning it may give this symptom.
check seat switch and related wiring also
check all fuses
  • Posted 30 Jan 2013 21:49
hello my friend, send your mail
my mail: alberto dot martins54 at gmail dot com
  • Posted 30 Jan 2013 12:01
  • By AMartins
  • joined 8 May'10 - 107 messages
  • vila nova de gaia, Portugal
anyone may send me a repair manual for this truck? thanks. liwan at juno dot com
  • Posted 30 Jan 2013 11:11
  • By li_w
yes, double checked again. the sevcontrol works good. anything other than sevcontrol relative this code?
  • Posted 20 Jan 2013 13:24
  • By li_w
Oh yeah of course it does. HAve you checked the spring inside the sevcontrol and also the plug on the harness directly out of the box
  • Posted 16 Jan 2013 05:46
  • By kevin_k
the pedal connects to the SEVCONTROL, which has a switch inside but works good. anything else I have to check?
  • Posted 15 Jan 2013 09:03
  • By li_w
On the throttle pedal
  • Posted 15 Jan 2013 05:39
  • By kevin_k
Toyota 8FG25
SMV (Konecranes) 12-1200B
Muncie, IN, United States
