Clark tmg20
I have a clark TMG 20 (sit down) Hydraulic lift function is very slow. could it be a fluid divider issue or possible pump going out. Im used to hearing the motor run faster as it lifts, stay at a low speed now the whole time. No codes. Can you help??
  • Posted 9 Jan 2013 09:48
  • By alvino_r
  • joined 22 Feb'12 - 13 messages
Are the switch's on the hydraulic control levers ok? is it making good contact and adjusted properly? How is the pump motor itself are the brushes good and motor cables tightand in good condition,is it getting full voltage?
Is the spool in the control valve getting full travel up and down when you use the control lever for lift/down?
  • Posted 9 Jan 2013 20:46
  • Modified 9 Jan 2013 20:50 by poster
  • By kevin_t
Ok im gonna look into that. No. The tilt and side shift work normal- just lift function.
  • Posted 9 Jan 2013 11:08
  • By alvino_r
Have you checked the lift potentiometer as this is what controls pump speed when lifting. TMG machines had a separate power steer motor so are not fitted with any flow or priority valve. Are all hyd functions slow?
  • Posted 9 Jan 2013 10:02
  • By danny_k
Muncie, IN, United States
Toyota 3FD100
UN Forklift FD30T-NJM1
