problem with load
Hello! Please tell me what could be the cause:
moving the load, the machine stops completely. The engine does not feel stress at all. On the control panel is a regulator of the effort, but I can not understand how it regulates the hydraulics. as far as I understand, all the executive solenoids have only ON. and off. I hope to help.
  • Posted 4 Jan 2013 22:53
  • By Ivan_L
  • joined 31 May'12 - 24 messages
  • DP, Ukraine
litvinivan@mail.ru
Dear Jeff, all loaders (wheeled or on tracks) can be configurated as forklifts.
  • Posted 9 May 2013 09:15
  • By StillCAT
  • joined 9 Apr'13 - 18 messages
  • Bucharest, Romania
That effort regulator you found on the dashboard transfers power between hydraulics or march (drive); your wheel loader is a hydrostatic machine: pump for drive with LS, flow and direction controls and two hidromotors for drive, mounted on a drop box.depending of travel speed these motors generate power.
That part code is not a Komat'su genuine.
In case you need a workshop Manual (pdf format), provide an e-mail adress AND the machine generation: 3, 5 or 6 (the number after the dash on the nameplate).
  • Posted 9 May 2013 09:10
  • By StillCAT
This is a Wheel Loader, not a forklift. So the knowledge to assist you maybe limited here.
  • Posted 7 Feb 2013 22:29
  • By Jeff
  • joined 8 Feb'07 - 61 messages
Found the reason for failure.
What should be the length of the part UC1700877569 (PIN,PARALLEL)? In the motor N1.
  • Posted 10 Jan 2013 04:43
  • By Ivan_L
  • DP, Ukraine
litvinivan@mail.ru
Elwell-Parker ESI500-36
Airman ENCL045
