Nissan forlklift mast
I'm looking for a complete mast for a 1990 Nissan model YGF03A4TV cap-lbs 8500 forklift it could be new or used
  • Posted 14 Dec 2012 04:05
  • By vincent_p
  • joined 9 May'12 - 5 messages
  • Quebec, Canada
vincent p;
The stamp numbers on the top of the outside rail right side would help to ID or it will have a plate that is glued on the rail with it's ID numbers. If these numbers can not be found then the chassis serial number and the dealer's line card that is available to an authorized dealer will identify the mast that was on the truck when it was shipped from the factory. Otherwise it can be identified by some measurements.
  • Posted 14 Dec 2012 22:44
  • By MEngr
  • Missouri, United States
