Slow movement
Hi
New ring gear put in forklift, back together, won't move backwards or forwards. Engine went back in clean. gas forklift 1986 model, mazda engine. Any help much appreciated.
  • Posted 1 Dec 2012 18:12
  • By AndyH
  • joined 1 Dec'12 - 6 messages
  • Nottinghamshire, United Kingdom
Lesson to all especially me... Wrong dipstick. ignored it filled to level bung next to filter and it has worked fine ever since. many thanks to all who commented.
  • Posted 1 Jan 2013 22:29
  • By AndyH
If these sypmtoms came only after the ring gear, I would check all wiring (for pinching), connectors & grounds. Does sound like an electric issue
  • Posted 5 Dec 2012 11:46
  • By bbforks
Hi thanks for taking the time to reply. You can sit on the truck and suddenly it will now work intermittently and someone else at work said it may be a switch, I never thought of electronic, thanks very much for the pointer. I will let you know for the benefit of all...
  • Posted 4 Dec 2012 19:50
  • By AndyH
Hi Kevin
The inching linkage? Sounds fun... I am a gardener with no money who is trying, what is an inching linkage/
  • Posted 4 Dec 2012 19:47
  • By AndyH
Have you checked the inching linkage
  • Posted 4 Dec 2012 03:38
  • By kevin_k
assuming the truck ran ok before the ringgear job
i'd go back and retrace the steps you took during reassembly
check wiring connections to transmission, ecm, check fuses, there should be a fuse controlling the transmission, make sure its not blown.
just a couple of things to consider
  • Posted 4 Dec 2012 00:21
sorry forgot the model
Its a Hyster hs50xl 1986 gas converted Mazda engine.
Cheers
  • Posted 3 Dec 2012 18:15
  • By AndyH
Hi
Yes, hydraulics are fine and all fluid levels are up to level?
  • Posted 3 Dec 2012 18:14
  • By AndyH
Are hydraulics working? What is model of truck
  • Posted 3 Dec 2012 02:43
  • By sean3
  • joined 14 May'11 - 46 messages
  • lancashire, United Kingdom
Oxford Ct, United States
Tusk 500PGH14
Esie Cortez Esie Cortez
