cat fork truck
I am new to fork lift repairs. I am in need of some advice. I have a older cat lift that shows an exclamation mark on he dash panel every time I speed up. It goes away when I slow down. It will not show this when I am at idle in neutral. Only happens in forward or reverse. Sorry I don't know the model#
  • Posted 29 Nov 2012 02:24
  • By bradley1287
  • joined 29 Nov'12 - 4 messages
  • Wisconsin, United States
if this is an electric 3 wheel sitdown, and i presume it is by you posting this in this forum thread, check the kickpanel (behind your legs), and also check along the front between the mast and front, sometimes they put a dataplate there. On these trucks they also stamp the serial number in the frame along the right side of the battery box.
without a serial number it will be hard to help with your diagnosis and give you accurate help.
as for the exclamation symbol showing does it have any other symbols showing? like a fork symbol or a motor symbol? generally it will have one other symbol lit up designnating which system along with the !.
  • Posted 29 Nov 2012 21:24
  • Modified 29 Nov 2012 21:34 by poster
Crown SX3030TT4250
Taylor TX330S
USD159,500
Crown SX3030TT4250
Taylor TX330S
USD159,500
Crown SX3030TT4250
Taylor TX330S
USD159,500
Esie Cortez Esie Cortez
