hyster E1.50XM error code 7
HI I have a Hyster E1.50xm year 2000 and fault code 7 come up when you press the accelator and clears when released. All other functions are working correctly.
Thanks
George
  • Posted 22 Nov 2012 07:43
  • By george_h
  • joined 22 Nov'12 - 2 messages
  • monaghan, Ireland
Accelerator input voltage too high when key is first moved to ON position.
Symptom
Lift truck does not move.
Possible Causes and Test Procedures
* Accelerator unit has a malfunction or is out of adjustment. Maximum accelerator wiper voltage should be 11.00 volts with the pedal fully up.
* Open circuit between accelerator unit and P7
  • Posted 22 Nov 2012 08:02
  • By geroj
  • joined 21 Feb'10 - 262 messages
  • Krivan, Slovakia
