Mitsubishi FGC25K w/ECU missing.
Lift idles perfect but when you rev it up it starts missing on cylinder #2 & #3 they lose spark intermitting have had the ECU rebuilt replace crank trigger and coil with known good parts still does the same thing.Any help would be appreciated.
  • Posted 16 Nov 2012 04:37
  • By Forklift1982
  • joined 16 Nov'12 - 1 message
yes a truck serial number would be helpful
but off the top of my head a couple of things come to mind here...
as edward said, insure the crank sensor is adjusted properly and the harness connecting it is not damaged in any way
also have you done a compression check on the cylinders? see if there is any difference across the board paying close attention to the no. 2 and no. 3 cylinders. its a long shot but a partially blown head-gasket may cause this symptom too.
just a couple of thoughts to ponder while scratching your head :o)
  • Posted 19 Nov 2012 22:15
I really should ask the serial number series, but I am guessing it is an 2004, af82e,
This crank trigger wheel is where your problem is. the gap between the sensor and wheel is extremely sensitive, measure the gap in at least 4 spots in the crank's rotation to insure the gap is the same. there is a special tool to get the sensor/trigger wheel to sit just right, but my bet is that if you get it the same all the way around, it will cure your problem. you will need to loose the 4 screws/bolts that hold the wheel to the pulley until you get it within only about 3 thousandth of an inch in differences (the width of a newspaper). You will also need to use a non-magnetic feeler gauge.
also, if you have the 'PSI display' software, you will need to put this into diagnostic mode and set the timing with a timing light twisting the distributor. you should also always be sure the software is set back into run mode, and not just disconnected or the computer shut down.
  • Posted 16 Nov 2012 22:19
  • Modified 16 Nov 2012 22:27 by poster
Deborah Baker Deborah Baker
JLG G12-55A
Taylor TT300
USD98,500
