Mitsubishi FG 25N
hello
I'm having trouble with some flaws on display
E21, E22, E23, E30, P03
I am looking for the service manual and fault codes
FG 25N AF17000460 E873576
  • Posted 10 Nov 2012 05:56
  • By forklift_brasil
  • joined 27 Sep'12 - 55 messages
  • rio de janeiro, Brazil
tecmanuais@yahoo.com.br
skype:hyster.brasil
Also check wires we have had acouple of broke wires on throttle senser (E 23 ) code. think it is caused from motor viberation and mitsubishi using to small of wire in wiring harness had a service tech tell me that he had fixed a lot of broke wires
  • Posted 10 Jan 2013 06:44
  • By Dave2013
  • joined 10 Jan'13 - 20 messages
  • Oklahoma, United States
failed P-04, F-04 mitsubishi FG25N AF17D000460
  • Posted 13 Nov 2012 23:21
skype:hyster.brasil
Thanks for the trouble
  • Posted 10 Nov 2012 09:48
skype:hyster.brasil
usually when you get all these codes popping up its one of 2 things on these trucks
like kevin said its voltage issues causing the system to get incorrect 'expected' readings therefore it throws random codes for everything.
-check the battery AND charging system
-check the frame ground over on the side of the frame battery side, make sure its clean, not painted, sometimes they would assemble the trucks and the ground point would be painted over... DOH!
-check the egi relays in the relay box, those have been known to cause these kind of issues as well. If they are the black relays replace them, the new ones are green and do work alot better.
as for a manual, thats a big no no
sorry
hope this helps
  • Posted 10 Nov 2012 08:53
E21 Mass air flow sensor signal circuit malfunction
E22 Engine Coolant temperature signal circuit malfunction
E23 Throttle Postion sensor signal circuit malfunction
E30 ECM System Malfunction
P03 VCM Communication Error
Sounds like maybe someone was troubleshooting while truck was running and unplugging sensors??
First thing i would check is the battery and make sure it is in good health and check the alternator belt and make sure its tight??
Is unusual to have this many codes pop up all at once??
  • Posted 10 Nov 2012 07:54
  • By kevin_t
Taylor TX175
New - Sale & Hire
Mitsubishi FD200
Muncie, IN, United States
Taylor TX175
New - Sale & Hire
Mitsubishi FD200
Taylor TX175
New - Sale & Hire
Mitsubishi FD200
