Towmotor/Caterpillar TC30? help
I just got a forklift the other day because I thought it would be what I needed. The data plate is missing, but it looks like a Cat TC30. It was apparently built not too long after Caterpillar took over Towmotor, because it has the Towmotor name on either side, and Caterpillar on the counterweight. It has a 4 cylinder gasoline Continental, 2 stage mast, no power steering, no side shift, no cage, and is hydrostatic. If anyone knows if it is not a TC30, please let me know. I bought it because it was low to go around in and around my shop and outbuildings. Big mistake. If it even looks at grass the traction tires just sit there and spin. It doesnt sink low enough to bottom out, but just sits. Anyone know of a dual front wheel conversion for these with 12 lug wheels? Anyone ever used the tire studs I have seen for ice to get traction in dirt? Anyone know of a pneumatic/press on type rim to convert this one off of the cushion tires? Also, my rear steering tires are VERY worn and thin, anyone know what size to get (these are all chewed up and say nothing). As I'm sure you can tell, I'm new to this forklift bidness. I hate to get rid of it, it runs great, lifts fine, has low top clearance so I can get it where I need to, I just cant do my outside chores with it. Plus, I think it is neat looking and I have an affinity for old iron, even if it is ugly (previous owner painted it pink for no reason, gotta fix that).
  • Posted 28 Sep 2012 03:02
  • By bigguy6100
  • joined 28 Sep'12 - 1 message
As John said it is what it is and can not be changed.
The serial # of the truck should be stamper on the frame below one of the tilt cylinders.
  • Posted 1 Oct 2012 21:31
  • By duodeluxe
  • United States
duodeluxe
If it says Towmotor on the side panels I suppose it could be a model 422S.
  • Posted 28 Sep 2012 05:39
Based on what you said the unit is a 1970 ish model. Caterpillar bought Towmotor in 1969. There are no conversions available to convert from cushion to pneumatic tires or adding dual from cushion units. For yard work trucks are designed longer and wider to reduce the ground pressure.
This unit is designed to work on the inside or on smooth concrete surfaces outside period - no off roading.
  • Posted 28 Sep 2012 05:14
  • By johnr_j
Muncie, IN, United States
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
JLG G12-55A
USD1
JLG G12-55A
Deborah Baker Deborah Baker
