Yale NDR030 Help needed
One of my technicians is replacing a lift pot on an NDR030SCM036TE095 and needs to relearn the system. I need the procedure to access the learn function.
  • Posted 12 Sep 2012 04:12
  • By jeff_g
  • joined 13 Apr'07 - 25 messages
It turned out that the pot wasn't working because the switch in the handle was normally open instead of normally closed. Swapped it out with a factory part and all is good. Thanks for all of your input.
  • Posted 8 Nov 2012 05:10
  • By jeff_g
this is an older truck no? as in before hyster/yale started using the long serial numbers?
serial number tells me so
where was it mfg'd at? if in north america then the SCM part of model number is wrong? wouldnt it be SCN?
this truck has no learn proceedure if i'm not mistaken.
you have to set it up manually (old school way) using an ohm meter.
i could be wrong but i'm pretty sure i'm not ;o)
  • Posted 6 Nov 2012 21:10
  • Modified 6 Nov 2012 21:20 by poster
Thanks Bruce, your email was removed from the post. mine is jeffg at mmhforklifts dot com
  • Posted 6 Nov 2012 06:19
  • By jeff_g
Jeff,
If you will drop me an e- mail to [email address removed] I will send you an Adobe of the section you need.
Regards,
Bruce Fraser
Yale Technicial Services
  • Posted 6 Nov 2012 06:15
  • By bruce_f
  • joined 4 Aug'10 - 8 messages
Sorry for the typo. NDR030ACM036TE095 s/n N592036
thanks in advance!
  • Posted 13 Sep 2012 22:02
  • By jeff_g
jeff,
Have never seen this model# before, send serial# and will see what I can find.
  • Posted 13 Sep 2012 10:14
  • By garland_m
  • joined 16 Oct'09 - 212 messages
  • Virginia, United States
Work Hard and Fish Long
Deborah Baker Deborah Baker
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Mitsubishi Logisnext FD25T5M
USD1
