Toyota LWE 40
hello
how to change the boot code in the LWE 140 forklift Toyota
without connecting a computer
Christopher greets
  • Posted 10 Sep 2012 15:12
  • By krzysztof_k
  • joined 2 Feb'11 - 129 messages
  • śląśk, Poland
You can easily change the code with the BT / Toyota service key - you DON'T need the computer to change the pin code.
Plug the BT / Toyota can service key in & then simply press the green button on the keypad, the truck will start up as the can service key bypasses any pin codes programed.
Is it an LWE Orion or an LWE Levio?
  • Posted 10 Sep 2012 22:34
  • By Forkingabout
  • england, United Kingdom
hello
I'm including a forklift have a numeric keypad key cit
I forgot the code and start
Do I have to have the cable and the computer to check the code?
if you can run it in a different way
Krzysztof
  • Posted 10 Sep 2012 22:14
  • By krzysztof_k
  • śląśk, Poland
What do you mean change the boot code?
What is it you are actually trying to change on the machine?
This is really a BT Rolatruc LWE 140 with Toyota stickers stuck on.
  • Posted 10 Sep 2012 17:36
  • By Forkingabout
