Forklift Nissan platinum 60
I need to know what is the code E-28 means in my forklift Nissan 60 I been working with this forklift for more than 2 years without problems until today I tried to start up but the motor wont run I changed the propane tank and nothing happen just the panel shows E-28, please let me know. Thank you.
  • Posted 8 Sep 2012 10:48
  • By feriletzy
  • joined 8 Sep'12 - 1 message
E-28 is for the camshaft position sensor signal circuit malfunction,if replacing a camshaft sensor it is also recommended to also chang the crankshaft position sensor.
Could be that the truck just needs new plugs, also Does this have the K21/K25 engine in it? How many hours are on the truck? Full Model and serial number?
Another possibility is the wires going into the sensor connector(broken wires),especially if a bunch of stretch wrap of floor debris gets sucked up into the engine compartment?
  • Posted 8 Sep 2012 13:26
  • By kevin_t
Muncie, IN, United States
