Hello Laci.
Raul writes the controller is in the back. If so, it has to be 3 controllers totally. The EFG with ZAPI has controllers in leftside and it is a B1 for traction and ZAPI HP for hydraulic.
Best regards, Max
Hello Raul. This forklift is with ZAPI controllers???
Your email adress? My is in my profile.
best regards, Laci
Hello Max,
Thank you very much for the information.
The back of the forklift, there are three a controller, but I do not remember the type.
Display showed the text, but I do not remember what.
I look at all the things you mentioned tomorrow.
Thank you once again, now possible to proceed with this problem.
Regards,
Raul
Hello Raul.
Error 54 is motor cable broken or cable for temperatur sensor. If you have changed controllers, check for bad connections. Also check the small connector (6 pins) on motor. Does display write any text beside error 54? Does this forklift have 3 MP1514 Controllers??? If so you can't replace or interchange controllers without reprogramming interface and controllers. Either by LISA or by laptop/judit.
Regards, Max
