linde h35t 393 dont starts
hy for all
y hawe one linde h35 t tip h2x393 yaer 2007 gpl vw motor
an y hawe a problem with start.all component is good.off display dont hawe error code.and wenn put the patfinder error cod 1,2,4,8,9,104.
all component I've tried all the components on another truck identic.carburator electrovalava regulator, delcou, all component are ok.
batt jack coming from the evaporator solenoid 12v current at startup and after drops and closes the gas.
Can you help me with this problem
the engine speed sensor is new cast is ok
controller and relays are good
kann help my please
  • Posted 19 Aug 2012 00:36
  • By adi_m
  • joined 5 May'12 - 75 messages
  • romania, Romania
adi
e mail adress metadonul @ hotmail dot com
Showing items 1 - 19 of 19 results.
SORRY FOR THE FIRST LANGUAGE
GOOD
HOW I told SEAT SENSOR IS THE BEST PEDAL I tried again even if there ALL START EL truck.
I changed the sensor on CROWN MOTOR second sensor is positioned WHERE
  • Posted 23 Aug 2012 19:52
  • By adi_m
  • romania, Romania
adi
BUNA
**** V-AM SPUS SENZORUL DE SCAUN ESTE BUN AM INCERCAT IAR CEL DE PEDALA CHIAR DACA NU EXISTA EL TOT PORNESTE STIVUITORUL.
AM SCHIMBAT SENZORUL DE PE COROANA MOTOR AL DOILEA SENZOR UNDE ESTE POZITIONAT ?
  • Posted 23 Aug 2012 19:49
  • By adi_m
  • romania, Romania
adi
Hi friend,
I assume that you know what the error 104 mean. But just think that:
Possible causes:
1. Cable connections between seat switch (S4)and controller (N1:33, N1:38) faulty.
2. Cable connections between pedal position sensor (1B2) and controller (N1:1, N1:32, N1:49, N1:61) faulty.
3. Seat switch (S4) defective.
4. Pedal position sensor (1B2) defective
These 2 signals are not synchronized each other may cause to stop the Engine to start. please check and try to clear this error before doing the next step.
Furthermore, This truck has 2 speed sensors : Engine speed sensor and truck speed sensor. So you need to check the other one as well. This is because the controller normally couldn't know if the speed sensor is in good or not so he never alarm an error for speed sensor problem.
Good luck
Nuna
  • Posted 23 Aug 2012 18:57
  • By Nuna
  • joined 12 Mar'09 - 189 messages
  • BK, Thailand
Thanks & Regards
Nuna
Email: nunatech2002@gmail.com
ANITHING HAVE ONE IDEEA
  • Posted 23 Aug 2012 18:46
  • By adi_m
  • romania, Romania
adi
sent you mail my friend
my mail adres is on profile
  • Posted 23 Aug 2012 04:09
  • By michel_v
  • noord holland, Netherlands
dont have other code
  • Posted 23 Aug 2012 04:06
  • By adi_m
  • romania, Romania
adi
control first foud code that does not make sense
  • Posted 23 Aug 2012 03:59
  • By michel_v
I did direct line gas engine still does not start
  • Posted 23 Aug 2012 03:43
  • By adi_m
  • romania, Romania
adi
make your gas line directly
and let the 12v line to the gas valve down and try this is
  • Posted 23 Aug 2012 03:01
  • By michel_v
hello
I checked two coils are blue block, spark safe figure.
but Moore stopped walking and has not started at all possible if you change the spark plugs vw all think you'll have good lighting.
how can I check aprindere.iar question why after 1 minute after starting inhide gas? but if put gas directly without solenoid will not start.
  • Posted 23 Aug 2012 00:18
  • By adi_m
  • romania, Romania
adi
As I understand, the engine starts and stops when the fuel is cut off.
Is it right (please adi m. confirm)
Timing setting,
I simply try to figure if everything is OK with the engine itself.
By timing I mean ignition timing.
Are the spark plugs OK?
I am still not convinced if it's not an LPG system problem.
If the mixer, for example, is dirty and the piston inside "hangs" it may cause similar outcome as you described.
The same with the coil. There were some very tricky issues with the ignition coils on 39X trucks.
The older (black) ones were behaving strange. It could happen, that on one truck it was OK, on another it was faulty.
Please confirm if you have the blue ignition coil.
Check if the wiring is OK. Perhaps you have some short circuit.
I will consult the issue with one of my specialists who serviced tens of such trucks. Maybe he finds something.
  • Posted 22 Aug 2012 23:33
  • By Karait
  • joined 21 Jun'09 - 355 messages
  • Poland
adi m, if you look at this truck's wiring shcematics and diagram it will give you the answer as to why the engine is spinning but not starting. When the starter is engaged a great deal of current is removed from the rest of the vehicle. This is shown by the voltage drop. Basic electrics it is the amount of current or flow of electrons that is needed to do work. To test my hypothesis you can spray a shop cloth with either and place it over the engine's air intake and allow the engine to just snif it while it is cranking and if the engine starts or just tries to start your problem is fuel related. However, if it doesn't attempt to start, the problem is electrically related.
  • Posted 22 Aug 2012 22:29
  • By MEngr
  • Missouri, United States
hello
I changed the valve and solenoid and I installed on another truck that runs four days. solenoid current I came directly from pre battery and the engine still will not start
Gas and vacuum circuit stops after 1 minute
I do not understand why the vacuum stops.
even create whole mouth vacuum gas does not come after one minute of starting the ignition key
ps watt intend with timing set properly?
  • Posted 22 Aug 2012 22:22
  • By adi_m
  • romania, Romania
adi
  • By MEngr
Hi,
I still suspect something is wrong with the LPG system.
Anyway...
Is the selenoid on the truck black or blue?
Should be blue, there were serious problems with the black ones.
Try to remove the piston from the LPG valve under the selenoid. The valve opens/closes when activated by the selenoid.
Without the piston, you should have the permanent LPG supply.
Check if the engine works.
PS
Is the timing set properly?
  • Posted 22 Aug 2012 21:48
  • By Karait
  • Poland
I know your deepest secret fear...
J.M.
hello
I tried all possibilities without pedal sensor seat without another truck just starts so h2x393 1,2,4,8,9,104 alarms are useless
I put a new battery and the truck has the same problem he spins the engine so there is no ignition problem.
Another problem is they gave direct current to the solenoid and so gas comes after two minutes and stops.
I just changed the solenoid.
  • Posted 22 Aug 2012 16:07
  • By adi_m
  • romania, Romania
adi
adi m, look at the truck's key switch for high resistance and a possible low voltage to the ignition module. If you are seeing 11 volts or less with a fully charged battery replace the switch and your problem should go away. Good luck & good service.
  • Posted 22 Aug 2012 12:39
  • By MEngr
start at the beginning:
do you have fuel going to the engine?
do you have a spark?
  • Posted 22 Aug 2012 04:47
  • By frits_f
  • joined 19 Dec'09 - 320 messages
  • utrechte, Netherlands
kann help my with linde 393?
  • Posted 20 Aug 2012 03:37
  • By adi_m
  • romania, Romania
adi
Muncie, IN, United States
Taylor XC300M
New - Sale & Hire
TCM FHD105Z
Taylor XC300M
New - Sale & Hire
TCM FHD105Z
