Weak power / over heating
Discovered turbo was bad and engine to pump coupling was bad. Replaced both along with new timing belt, water pump, and thermostat. It still has reduced power (rpm's reach no higher than 1,900 or so under a load) and is still overheating. It builds up enough pressure to spew coolant out of the coolant reservoir cap and temp of about 260 degrees. I'm thinking a bad head or head gasket. Any thoughts?
  • Posted 17 Aug 2012 09:46
  • By chilidawg
  • joined 1 Jun'12 - 10 messages
When replacing turbo, engine has to be recoded I believe.Do a cylinder leak test
  • Posted 24 May 2015 07:02
  • By edward_m
  • joined 11 May'15 - 111 messages
Terberg YT222
Enforcer FLBAXT25
Yale Lift Truck Technologies
Michel Denis Michel Denis
Terberg YT222
Enforcer FLBAXT25
