Toyota 7FDU35 not lifting enough
Hello all. I have a customer with a large lumberyard and he runs several 7FDU30's and one 7FDU35. I have known the operator for many years and he has always taken care of his equipment. Recently I heard complaints of the mast "hanging up" and after inspection I found that there was significant clearance between the inner and intermediate channels (FFT). The primary lift cylinder had also began to "fluid lock" and the the free lift was only about 1/2 way up before the secondary cylinders began to raise. We resealed the free lift cylinder (piston seal was crumbling) and I did a follow up a couple of days ago. Fred tells me it's still "hanging up" a huge bundle of pine 2x12's, which it lifts fine until halfway through the second stage where it quit moving. He tells me it use to lift the same size bundle in treated lumber which is heavier.
Fast forward to today. I tapped in and checked the main relief pressure. I had 2700 psi when tilting back in relief, spec is 2630 +-70 psi so nothing there. Any ideas?
Toyota 7FDU35 S/N:62361
  • Posted 16 Aug 2012 06:35
  • By Forkliftt
  • Louisiana, United States
Steve
steve at forkliftt dot com
Good point. And this application has those type problems.
  • Posted 15 Oct 2012 10:46
  • By Forkliftt
Steve
I have seen bouncing with heavy loads destroy the packings as you describe. I would advise an accumulater in the hoist cyl circuit to alleviate this type of problem in the future.
  • Posted 15 Oct 2012 07:36
  • By bbforks
Thanks for the response SM. Problem was repaired about a week ago. I determined it was not a mast mechanical binding problem, and felt the oil was getting on top of one/ both the secondary lift cylinder pistons and the center check valve was stuck or blocked, causing the presumed oil on top of the pistons to "fluid lock" the cylinders. I ordered the kits and hauled to the shop, removed and disassembled cylinders. What we found were both piston seals blown, cracked up. However, the check valves were fine, and no debris was found in the hollow section of the tubes. This is a common failure on lots of OEM cylinders, and Cascade as well. But never with the "loading" symptoms we had on this particular machine. What I did notice was the hollow cavity on these tubes was only about 12" deep. Not the entire tube as is common. My theory is that a bigger hollow cavity would allow more oil/ air to push internal when the cylinder begins to leak- allowing a cushion of air to compress. The smaller cavity- not much ability to compress. Would love to hear some feedback. Thanks all.
  • Posted 13 Oct 2012 02:51
  • By Forkliftt
Steve
sounds like you have a small dent in your first stage cylinder (seals chewed up) ,run your hand on front of cylinder barrel, it does not take much to cause misstage
  • Posted 13 Oct 2012 02:26
  • By snowmonkey
  • joined 13 Oct'12 - 36 messages
  • Alberta, Canada
I am thinking also that it is mast binding,especially if heavy loads are involved.
  • Posted 16 Aug 2012 10:08
  • By kevin_t
Kevin, there is a lot of play in the mast. This machine only has 300o hours on it, but it carries heavy, very wide loads over uneven ground. I suspect it could be a mechanical bind on the mast. I have sprayed mast lube on the slide areas.
  • Posted 16 Aug 2012 09:47
  • By Forkliftt
Steve
How are the mast and carriage rollers,any broken and hanging up in the channels? Rails worn? rollers may be bad or needing shimmed if the rails are worn to much.
What leads me to think this is your comment, "significant clearance between the inner and intermediate channels (FFT). "
  • Posted 16 Aug 2012 09:30
  • Modified 16 Aug 2012 09:31 by poster
  • By kevin_t
rogeriwt:
I have repaired some toyotas with that problem,changing the seals of the lift cylinder and the check valve in the bottom of the ram,
maybe that helps.
  • Posted 16 Aug 2012 08:57
  • By pastrana_j
  • joined 3 Aug'10 - 103 messages
  • Puebla, Mexico
Have you checked the fluid and filters?
  • Posted 16 Aug 2012 07:22
  • By rogeriwt
The origin of "love" as the score zero in tennis is debated, but two main theories prevail. One suggests it's derived from the French word "l'oeuf" (egg) which resembles the shape of the number zero. The other proposes it's related to the Dutch word "lof" meaning "honour" as players might be playing for honour when scoreless.
Komatsu FD25T17
UN Forklift FGL18T
