linde e14-01 2008
hi if anyone can help it would be greatly appreciated.
im currently working on a linde e14-01
serial h2x386w03457
fault codes showing
t861_L225
L286_L820
t421_l225
L286_L820
t421_L225
L286_L820
t861_L225
L286_L281
T921_T421
i kinda figure one of these relates to pump motor speed sensor, the truck runs fine until the pump motor ramps up full speed, the list of errors above have all come up on different occasions but figure as much info as possible helps come to a speedy answer.
today i swapped the speed sensor on the hydraulic motor with one in the drive to get different errors which i kinda expected
T312
T861_T312
L225_L861
T921_T821
T931_T421
T861_T312
T412_L225
any ideas guys?
  • Posted 16 Aug 2012 05:01
  • By andy_j
  • joined 16 Aug'12 - 38 messages
  • Uk, United Kingdom
Andy_w_jones@hotmail.co.uk
yes andy,
even as handy as those ezfill systems are they are not fullproof. They do require maintenance and those cap floats and level indicators do stick after a while.
I had one in a reach truck one time that the floats would not shut off the water completely and wound up spilling onto the floor from a couple of the cells, overfilling those cells, i had to replace the caps on those cells.
It pays to check them once in a while physically to make sure all is in good order with the caps, hoses etc.
  • Posted 13 Sep 2012 02:41
Finally got to the bottom of it, emergency stop checked out ok, tried running on the other trucks battery set and all worked fine, if i can give anyone a tiny bit of advice, dont rely on autofil systems to show electrolyte levels, all markers were up but the cells were pretty much empty, 35 litres of water later and all is fine, thanks for your help guys.
  • Posted 13 Sep 2012 00:45
  • By andy_j
Michel v is right.
The emergency switch (main switch) is the one you didn't report you have checked.
This may be there.
  • Posted 13 Sep 2012 00:24
  • Modified 13 Sep 2012 00:24 by poster
  • By Karait
  • joined 21 Jun'09 - 355 messages
  • Poland
hef one good look on emergency Stop button for good conexion
  • Posted 12 Sep 2012 02:15
  • By michel_v
  • noord holland, Netherlands
So the speed sensor was def faulty new one fitted today and now pump motor ramps up to full speed with no faults, traction is fine, but combine the two and it still throws up T312 or L286 at probably 3/4 to full pump speed. iv checked all connections large and small wires, slight corrosion on the pos battery take off, replaced it anyway. The truck has gone through a complete charge cycle and all cells are at 2.11/2.12 standing charge battery at 50.92v so close yet so far, there is another truck of the same model/spec so i will try switching batteries but dont think ill find an answer, any ideas guys?
  • Posted 11 Sep 2012 05:37
  • By andy_j
I wonder that symptom has 386 linde, malfunctioning since for one thing to have poorly will give many codes that will not have to do with the failure that you have to be able to help you,
  • Posted 17 Aug 2012 04:57
  • By juanpascual_t
  • joined 10 Aug'12 - 24 messages
  • Spain
Jhon_T
Hello Andy
One by one:
T312 - battery voltage too low
T860-863 - traction Power Module leftside error
L225 - pump motor doesn't reach the proper speed, although the signal from the controller is present
L286 - too low current on lift joystick
T421-425 - the communication between Can bus and power module rightside is faulty.
T900-963 - power module rightside error
L800-863 - lift power module error
T411-415 - the communication between Can bus and power module leftside is faulty.
Uff - looks like total disaster.
But probably the problem lies in:
1. Power supply. Check battery, high voltage cables, fuses, main switch, cable connections.
2. Electric motors. These are 3-phase AC motors and any short circuit can give very strange output
3. Least possible but possible. Earth connection.
It may happen that the truck gets "loaded" and needs to be connected to the earth.
Good luck
  • Posted 16 Aug 2012 18:57
  • By Karait
  • Poland
Kalmar-Ac P100CXD
Enforcer FD50T-MMA
Muncie, IN, United States
Deborah Baker Deborah Baker
Kalmar-Ac P100CXD
Enforcer FD50T-MMA
RAEDER-VOGEL
Kalmar-Ac P100CXD
Enforcer FD50T-MMA
