Hyster E60XM-33
After a complete charge only the hydraulics work. No driving functions work. Any ideas?
Thanks.
  • Posted 10 Aug 2012 07:55
  • By ATK1
  • joined 27 Jan'12 - 74 messages
  • South Dakota, United States
allenk@ntlifts.com
If _no_ codes, must be older than one that has codes, so you will need to check the voltages (assuming it is an ev100, at the tb1 through tb6) for correct input to the logic.
or fuses, check the fuses.
  • Posted 12 Aug 2012 06:41
  • Modified 12 Aug 2012 06:41 by poster
Sounds like a start switch issue to me. Check for debris around the throttle pedal that could be stopping the start switch functioning
  • Posted 10 Aug 2012 16:01
  • By kevin_k
Nope there are no codes. Already checked the contacts. Will look at the brake and seat switch. Will get serial number if that helps tomorrow morning.
Thanks.
  • Posted 10 Aug 2012 11:14
  • By ATK1
allenk@ntlifts.com
serial number?
Error codes?
what does happen? power steer? contacts? brake switch? seat switch?
  • Posted 10 Aug 2012 10:29
