toyota 8fgcsu20
Truck will not start. will spin over. The fuel shut-off is not actuationg and truck is not firing ingnition wise. I can manually make fuel shut-off actuate but still will not fire. I have swapped computers and still no fire. Can anyone give me any suggestions on where to look next. Also its throwing a code of AD-1
  • Posted 6 Aug 2012 03:25
  • By mark_l
  • joined 12 Mar'10 - 19 messages
I would check all fuses and the distributor plug on the side. I have seen the wires on the distributor plug break. They can be repaired but be careful the smaller of the 2 wires(tack signal wore) is a shielded wire and if you crimp the shield than it grounds it out and won't work. That is where I would start.
  • Posted 7 Aug 2012 07:51
  • By rogeriwt
Muncie, IN, United States
Deborah Baker Deborah Baker
