Still RX50- Error code 3909 - Please help
Hi friend,
I have problem with Still RX50, code 3909.
Basing on this instruction from service manual, I have already checked :
The canbus system is OK.
Have tried to flash the truck software.
But the truck still has problem: it always stops to alarm error 3909 and no traction. Sometimes it could run in slow speed.
Please check and help
Thanks you very much
Nuna
  • Posted 4 Aug 2012 23:15
  • By Nuna
  • joined 12 Mar'09 - 189 messages
  • BK, Thailand
Thanks & Regards
Nuna
Email: nunatech2002@gmail.com
Hello Nuna
Your error is interested.It would be great if you have another same truck to try some parts.When you do acc on pedal pot look in screen and read is it voltage in operating values if not you need to move pot with hand and than to calibrate.Is it wiring of pot ok?
look battery on display sometime she know to be problem on still trucks just check it.And look CAN good because error that you have says that display dont receive data from traction converter.
If you can please replace pedal pot or every part that you think that dont work good,Calibrate all needed and check truck data are they ok for that vehicle.
Tell me what are you do.
Good Luck
  • Posted 7 Aug 2012 01:21
  • By nemanja_k
  • serbia, Serbia
Thanks Nemanja, I have checked the speed sensor - canbus and cleaned all the connection of the inverter. Now the truck can run without error code but only on creep speed.
I have used the Steds diagnostic to check the acc potentiometer voltage, i saw that when the drive inscrease the speed from 0-50% max speed the truck speed will follow - on the other hand if the driver increase more than 50% the speed will be dropped down to Zero again. I have done calibration the Acc. potentiomtera again but the problem is not solved yet.
Do you have any more experiences on this matter ?
Regards
Nuna
  • Posted 5 Aug 2012 19:05
  • Modified 5 Aug 2012 19:07 by poster
  • By Nuna
  • BK, Thailand
Thanks & Regards
Nuna
How I sow watchdog operate but no traction,if you check wiring and if can is ok check speed sensor and component of controller to avoid possibility of blocking controller, If everything is ok replace or open controller and check it.
Good luck with error.
  • Posted 5 Aug 2012 03:54
  • By nemanja_k
  • serbia, Serbia
Tusk 500PGH14
Toyota 02-8FD25
Tusk 500PGH14
Toyota 02-8FD25
Deborah Baker Deborah Baker
