Clark ECS25 SCR Hydraulic controls
Serial #E357-0047-6865FB This is the high performance model. I lost hydraulics.Power steering OK.Everything seems to be OK.switches,fuses,wiring,etc..I can push in contactor and motor works.Also works when I tried to check continuity between #55 on contactor and # 50 on driver.It has new driver,rebuilt card and 1A contactor.I also tried #3 rec.I've gone thru schematic and found nothing that could be wrong.Any help would be graetly appreciated.
  • Posted 31 Jul 2012 11:36
  • By jim_k
  • joined 28 Aug'08 - 21 messages
hve had similar issues with hyster with pump card found it was #2 rec (handyman bench test did not reveil fault)
  • Posted 13 Oct 2012 02:41
  • By snowmonkey
  • joined 13 Oct'12 - 36 messages
  • Alberta, Canada
Are you getting B+ to the contactor coil? The B- side is controlled by the card via the pump contactor driver. What is the BSOC? Is it possible you are in lift interrupt?
  • Posted 1 Aug 2012 07:03
  • By LTRM
  • joined 26 Jan'12 - 161 messages
  • Illinois, United States
Muncie, IN, United States
UN Forklift FBRS15KQZ2
Toyota 4FD240
