Still R70-80 1999 drive forwards in neutral and reverse?
Hi , i have a crazy error in a Still R70, truck drive if you touch the accelerator pedal and can not stopping if you release the pedal ,after 10 seconds it stops it is very dangerous, i set the direction lever in neutral or reverse ,it drives forwards.. Dash light comes up if the lever in neutral. I check the wiring and connectors and lever switches but everything oke, Any idea were i can search or check?
  • Posted 21 Jul 2012 01:29
  • By gc_d
  • Zuid-Holland, Netherlands
Regards gc_d
hi i have been told it is the control card front one just bought one off ebay hope it will fix it will let you know regards dave.
  • Posted 7 Dec 2012 05:21
  • By granitedave
  • joined 10 Jun'12 - 5 messages
  • south yorkshire, United Kingdom
Hi , no i have not fix it , i think the right controlcard on the front are defect but i am not sure. I hop you have an idea?
  • Posted 7 Dec 2012 05:14
  • By gc_d
Regards gc_d
hi i have the same problem with my still r70 diesel stuck in drive cannot get it out have you fixed the problem if so can you let me know regards dave?
  • Posted 30 Nov 2012 05:09
  • By granitedave
serialnumber is 517046001095
regards
  • Posted 23 Jul 2012 15:24
  • By gc_d
Regards gc_d
which is the truck serial number?
  • Posted 21 Jul 2012 23:40
  • By nacsand_n
  • joined 20 Sep'09 - 716 messages
  • Madrid, Spain
Hi the conactor on the left side under floorplate comes in with engine on so ithink this is oke , i have check the four diode blocks by the contactor and check oke. You think the right module on the front of the machine ? powermodule 2a1 ?
  • Posted 21 Jul 2012 14:40
  • By gc_d
Regards gc_d
If wiring is OK, probably any transistor/transistors burned in power module. You should remove it to check. Do not open C26 contactor?
Regards
  • Posted 21 Jul 2012 03:23
  • By nacsand_n
  • Madrid, Spain
IMHX to become a biennial event Birmingham, United Kingdom
VETTER Industrie GmbH
Mike Barker Mike Barker
President and CEO Swisslog Americas, Swisslog
Vice president, Newgentech Material Handling India
Sales representative, Alabama and Panama City, Thompson Lift Truck
Chief marketing officer, Bobcat Company
