Combi CL40173LC58
I have a combi, when pressing the inching pedle down the trans. does dump and works as it should. But when the pedle is all the way aplyed the unit can still roll. Is this normal.forword and rev. are normal.
  • Posted 18 Jul 2012 03:36
  • By karmen_e
  • joined 8 May'12 - 2 messages
  • Ontario, -
I have some new trucks. the left pedal have an electrical switch, then there is not a brake pump asociated to this pedal.
when you press it, the trucks does not have traction, and slowly will stop. But if you are in a tilt, the truck will go down still if you are pressing the left pedal.
If you need to stay quiet the truck completely, you have to press the brake button that is in the levers zone (red button)
I hope was useful,
  • Posted 14 Aug 2013 10:32
  • By andres_v
  • joined 9 Dec'09 - 37 messages
  • CABA, Argentina
Always in movement
The Brakes should turn on when you press the Brake/Inch pedal.
You might have to replace the dump valve. Part# CPHY0003-00 in stock. Run pressure test to confirm
  • Posted 26 Jul 2012 21:55
  • By Prentice
if this is a combi lift 4 way i believe that the newest ones still drive with the pedal right down , we had one contacted combilift they said the driver manual states that the stop button brake sould be applied before revving in gear
  • Posted 26 Jul 2012 07:21
  • By trevb
  • joined 10 Jan'12 - 157 messages
  • avon, United Kingdom
No for all vehicle is same when you pres inching pedal down you turn off gear box and if your machine still roll you have problem somewhere in sistem it is like on car with manual gearbox.I think that you understand me.
  • Posted 18 Jul 2012 05:19
  • By nemanja_k
  • serbia, Serbia
David Wells David Wells
Chief executive, Logistics UK
National business development manager, Roadpod
Senior vice president, PEAC Solutions
Board director, UKMHA
edition #1242 - 7 August 2025
In this week’s Forkliftaction News , we take a closer look at the main theme coming out of the recent CeMAT Australia event in Sydney: automation; why some are holding back and why not everyone will automate... Continue reading
UN Forklift FBR25NQC3
SMV (Konecranes) 20-1200B
October 15-16, 2025 - Las Vegas, United States
November 13-14, 2025 - Berlin, Germany
Atlanta Savannah Orlando Tampa Jacksonville West Palm, United States
Sioux Falls, SD, United States
