Linde H18T(350-03) could not start the engine
No any error in window 2 (truck doctor) but no voltage to 1Y5(shutoff solenoid), 1Y4 (enable valve) and 1Y1 (butterfly RPM valve; disconnect 1Y5 and supply 12VDC directly, engine can start but without RPM control: window 6: nB1:0 even engie running ; have replaced new RPM sensor and LHC module but problem are the same.
Any one have experience with this problem before, please give me a help.
Thanks,
  • Posted 14 Jul 2012 14:21
  • By dang_n
  • joined 11 Nov'11 - 20 messages
  • Ho Chi Minh city, Viet Nam
dangnguyentam@yahoo.com
Hello Herald,
Another point: window 12 showed: Ctrk: 00 11 (351 truck) but according service manual , it should be 11 11 (350). pls advise.
  • Posted 3 Aug 2012 20:48
  • By dang_n
Dear Herald,
I tried to replaced two modules but no effect, I want to add that the LHC warning light always ON, no any powered supply to shutoff valve, RPM valve and enable valve. In window 3, error code is 28 but not 23.
Thanks,
  • Posted 3 Aug 2012 20:33
  • By dang_n
Hi Dang
Sorry to have not got back to you sooner, error code 23 is a coding fault the module does not recognise what the truck is. Have you tried another module? In window one are you getting the correct truck details?
Error code 23 will give you the symptoms you have. If module is ok you may have a loom fault, check the plug into the module first then work back following the wiring diagram.
Regards
Herald
  • Posted 27 Jul 2012 06:59
  • By Herald
  • joined 3 Jan'07 - 128 messages
  • lancashire, United Kingdom
Hello Herald,
Thanks for your assistant.
Yes, all fuses are OK including all ground which connected to module , already teach in the acceleration pedal with new module (exchange service from TVH) , window 3 of new module showed one error 28: 3.
For your reference of old module: window 2: 53,51; window 3: 34:3,71:9,37:9,44:8,31:9,32:9,33:9,53:9,73:6,51:8,88:6,57:6,38:4,28:1.
best regards.
Dang
  • Posted 20 Jul 2012 15:15
  • By dang_n
Hi dang
The module must be seeing a fault and is then not giving an enable signal to the lock off valve, the butterfly magnet and drive release valve, have you checked the fuses that supply the module they are under the dashboard one is 1amp the other 15amp, wiring the valves direct will prove they work but not solve your original problem. Did you teach the new module with a laptop, what faults do you have in window 3 ?
  • Posted 19 Jul 2012 22:54
  • By Herald
Hello ddrr,
thanks for advise about shutoff solenoid and how about RPM butterfly valve ? how to power it ?
There are minus 12VDC at two pins both shutoff and butterfly valves but no ground.
best regards,
  • Posted 19 Jul 2012 12:15
  • By dang_n
shutoff solenoid uses alternator voltage, only power when cranking or running. i
If this has throttle magnet box, it goes full stroke when keyswitch on then comes back when running,
put 12v power/ ground to magnet it should go full stroke
  • Posted 19 Jul 2012 09:52
  • By ddrr
  • joined 27 Jul'06 - 16 messages
  • Alberta, Canada
Ice 28INCH-AUTO-SCRUBBER
USD8,350
Taylor X550M
Deborah Baker Deborah Baker
USD8,350
Taylor X550M
USD8,350
Taylor X550M
