็ํHYSTER ERROR CODE
I have HYSTER MODEL E30XM S/N D114V021760
Lift system is ok. When I go forward it show code E02 and go backward it show code E03.Sometime it show E05.
Please help me.
  • Posted 12 Jul 2012 00:50
  • By pattaya_j
  • joined 12 Jul'12 - 11 messages
  • Thailand
MENGRAI555@gmail.com
Thanks for any answers. I will check.
  • Posted 12 Jul 2012 22:56
  • By pattaya_j
  • Thailand
Make sure your battery isn't dead/bad/out of water or that you're losing voltage somewhere when you put a load on the machine.
I've seen machines throw these codes when the voltage drops low when the contacts pull in. The increased load drops the battery volts, the contacts lose their holding current and drop out. Power comes back when the battery recovers cause the load is removed. It's like turning the key off and back on real quick.
Check your battery. Always check your power supply first.
  • Posted 12 Jul 2012 14:01
  • By justinm
check foward reverse lever/monotrol, brake switch, start switch, key switch, and all associated wiring if all these check good then problem is most likely in the control card
  • Posted 12 Jul 2012 08:33
  • By certifiedtech
  • joined 5 Aug'10 - 39 messages
Muncie, IN, United States
Deborah Baker Deborah Baker
