Caterpillar EP 16KT ETB 4A00374
Hello everybody. In the display of the above truck there is an exclamation mark and the truck is not working at all. Is anyone knows what this means. Thank you.
  • Posted 10 Jul 2012 16:33
  • By Touristas
  • joined 14 Jan'12 - 30 messages
  • GREECE, Greece
Hello John, thank you very much for your answer. I will check it out.
Best regards
  • Posted 12 Jul 2012 18:35
  • By Touristas
  • GREECE, Greece
ok, sorry bout the confusion on the serial number, i must have looked at it wrong, i rechecked it and it is good :o)
first make sure you battery is fully charged before testing
now... for the codes
code 51 is an accelerator sensor fault
check the accelerator and make sure it is returning completely back to neutral. Either trash or the floorpad can get under the heel of the pedal and not allow it to return all the way back.
Once you rule out this and it still gives code then the sensor itself may be bad or just out of adjustment and needs to be reset/re-calibrated.
as for code 30
this indicates an armature fault P
P being the pump circuit
check all your wiring and power cables to the pump motor and check the brushes in the motor.
  • Posted 11 Jul 2012 21:04
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Email: jplayer@liftone.net
Hello John. Thank for your fast reply. There are not any other symbols displayed on the dash.I have error codes 51 and 30 and the serial is corect ETB4A00374.
Best regards
  • Posted 11 Jul 2012 16:23
  • By Touristas
  • GREECE, Greece
are there any other symbols illuminated besides the !?
are there any number codes being displayed on the dash display?
also the serial number you provided is incorrect
would it happen to be ETB4B00374? please double check this first
  • Posted 10 Jul 2012 21:23
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Unicarriers FD80-2
Ice 28INCH-AUTO-SCRUBBER
USD8,350
Unicarriers FD80-2
USD8,350
Deborah Baker Deborah Baker
