LINDE H18T
Hi all
Customer has a Linde H18T03 H2X350L03 YOM 2000
The throttle is not responding to the accelerator pedal and the gas solenoid has lost its feed. Do I need a laptop etc and are the faults related. I would appreciate some input so I know how to proceed
  • Posted 27 Jun 2012 22:51
  • By nick_c
  • joined 17 Jun'11 - 116 messages
  • south glos, United Kingdom
hi techs im joining linde sterling in a couple of wks and wondering if anyone has worked at jag halewood could give me any insight
  • Posted 1 Jul 2012 21:55
  • By silversurfer
  • joined 1 Jul'12 - 5 messages
  • n/a, United Kingdom
the lpg lock off runs off a/c voltage, so it won't have power with
key on, only when cranking,
if this unit has that big throttle magnet it goes full stroke
with key on then comes back when running,
if it doesn't go full stroke(key on) throttle magnet(servo) is likely bad
  • Posted 29 Jun 2012 13:27
  • By ddrr
  • joined 27 Jul'06 - 16 messages
  • Alberta, Canada
you also have a light flashing on dasbord??
  • Posted 29 Jun 2012 02:47
  • By michel_v
  • noord holland, Netherlands
the gas soleniod is not linked to the throttle pedal it is ignition supplied the throttle pedal has plastic gears with a potentiometer check this first,have you checked all fuses ? there is some also under the hydraulic levers hope this helps
  • Posted 29 Jun 2012 01:01
  • By fred9691
  • joined 25 Jan'12 - 11 messages
  • somerset, United Kingdom
gina@jina.orangehome.co.uk
UN Forklift FGL18T
SMV (Konecranes) 16-1200C
Deborah Baker Deborah Baker
UN Forklift FGL18T
