ZAPI MPB or COMBISEM1
Has anyone repaired a ZAPI MPB or COMBISEM1? I have to replace MOSFET transistors, but it is very difficult to remove and solder MOSFETs. I've used a soldering station but my results are of poor quality. Is there any tool or method to solve it?
Thanks in advance
  • Posted 9 Jun 2012 23:15
  • By silvio
  • joined 30 Sep'08 - 29 messages
  • buenos aires, Argentina
EMAIL silvio_jorge@hotmaildotcom
Hola gabriel! Utilizé una plancha para precalentar (temperatura entre algodón y seda). La verdad que el trabajo fué muy rápido y quedó muy bien. Gracias por tu ayuda.
Ahora estoy luchando con un equipo zapi MPB que acusa falla "contactor closed".
Saludos y gracias de nuevo.
  • Posted 7 Sep 2012 11:17
  • By silvio
Hola Silvio, como te fue con el procedimiento para cambiar los mosfet? Saludos!!
  • Posted 7 Sep 2012 08:52
  • By gabriel_c
  • joined 1 Jul'09 - 2 messages
  • Buenos Aires, Argentina
HI there
We have recently began receiving some AC Zapi controllers, which have their mosfets mounted direct to a heavy aluminium heat sink, we have had difficulty however found that depends on the components near and around the mosfets area you might be able to get the solder to melt if you utilise a heat plate whilst soldering.
  • Posted 13 Jun 2012 02:36
  • By elektrodrive
enquiries@elektrodrive.co.uk
em port.
Olá Silvio Castillo!
Para trocar os mosfet da placa de potência
Você pode colocar a placa sobre um ferro de passar roupa
Você deixa um pouco a placa com a parte de ferro em cima de um ferro de passar roupa
Ajudando aquecer o estanho
Com auxilio de um ferro manual
Com qual linha de empilhadeira você trabalha
Você trabalha com conserto de controladores
Meu skype:hyster.brasil
Ingl.
Hello Silvio Castillo!
To change the card's power mosfet
You can put the plate on a clothes iron
You leave a little card with the iron on top of a clothes iron
To help heat the tin
With the help of an iron hand
Which line of forklift you work
You work with repair of controllers
My skype: hyster.brasil
  • Posted 11 Jun 2012 10:09
  • By hysterbrazil
  • joined 10 Oct'11 - 101 messages
  • rio de janeiro, Brazil
hello silvio!
you could send me a copy of the photo for me?
I'm starting to work on repairing controllers
ZAPI and curtis
if you need a manual or ZAPI curtis inform me
add me to skype: hyster.brasil
  • Posted 10 Jun 2012 07:12
  • By hysterbrazil
I look forward to the picture. Otherwise, the 100W is not small, just be a mass of mountain. Thicker copper build to a peak, not to cool it as soon as you touch the soldering process. I tried to send you an email, but something was wrong with the address. The mine can be found on the site. Zapi be drawing?
  • Posted 10 Jun 2012 01:37
  • By LACI
  • joined 24 May'09 - 195 messages
  • Serbia
Hello Laci thanks for your reply. A 100W soldering iron is very small. I'm using a 250W soldering iron. I will send you a photo so you can see.
  • Posted 10 Jun 2012 01:21
  • By silvio
Hello,
make your own tools. A copper plate as if it were to file the saw teeth are prepared. The three peaks will comply with the distance between the foot transistors. This edit least a 100W soldering tip and move on. Asawhole this must be heated in all three legs. But before you choose all the transistors of the cooling disk. Good job.
best regards, Laci
  • Posted 10 Jun 2012 00:55
  • By LACI
  • Serbia
SMV (Konecranes) 33-1200C
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Muncie, IN, United States
