Mast or hydraulic trouble
I have a clark c500-60
Having trouble with mast, it will rise slowly or with acceleration, take all the way to top it will stay anything else it slowly drops. will go down slower with lever in lfit postion.
Is this a hydraulic presssure or cylinder problem.
Any help i would appreciate
  • Posted 8 Jun 2012 22:52
  • By khans
  • joined 8 Jun'12 - 3 messages
  • Illinois, United States
yes bbforks
that is exactly why i put that comment at the bottom
NONE of this job should be done by a novice period!
let the professonals do it ;o)
  • Posted 6 Jul 2012 09:14
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Email: jplayer@liftone.net
Have a forklift mechanic pack the lift cylinder. The mast can hurt you real bad. Dont try it!
  • Posted 6 Jul 2012 01:56
  • By clay_d
  • joined 6 Jul'12 - 5 messages
Jplayer- you're absolutely right. I'm just afraid to have folks start removing hydraulic lines when the forks are up in the air. I've learned the hard way that sometimes what you say is not what is heard.
Khans- if you decide to remove hydraulic lines- the hydraulic line that is connected by hose clamps is the return line. DO NOT- I REPEAT- DO NOT- Remove any hydraulic line that is secured by a nut that is part of the hydraulic line. All pressure type hydraulic lines have built in hex head connectors. SERIOUS injuries can happen when hydraulic lines under pressure are suddenly disconnected.
-nuff said
  • Posted 21 Jun 2012 07:37
  • Modified 21 Jun 2012 07:43 by poster
  • By bbforks
if its dropping 10ft in 10 seconds you have a serious issue
my guess is since it is what you say a "single cylinder" that it is a multistage telescopic cylinder? or is this just a simplex mast freelift (does not go up very high)
my best guess is you have some packing issues in the cylinder allowing the rod packing to bypass.
The thing about it slowing down when you pull the lift lever is only that it is applying pressure to the cylinder trying to raise it back up. But if it is still falling down while you have that lever pulled it sounds like an internal cylinder issue. (packing).
If when you raise it all the way up and leave it for a while see if it bleeds down then, when raising it up to the top it might be putting enough pressure on the cylinder to hold it there temporarily? or just applying enough pressure on the packing to expand it and then it holds.
There is one test you can do, when you have it raised up pull the return line off and see if there is any drainback. You may get a slight bit but it shouldnt be alot. If you get more than a trickle then you may have a bad control valve or check valve issue. Now when i say return line i DO NOT mean the line going from the control valve to the cylinder, i mean the big hose going from the control valve back to the tank. By all means DO NOT loosen the pressure line while it is up in the air, that is very dangerous and will get you wet with oil in the process. Not to mention the forks will be comming down quickly too!
If your not sure about any of this hire a professional tech to troubleshoot it and repair it.
  • Posted 21 Jun 2012 06:50
  • Modified 21 Jun 2012 06:52 by poster
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Having the same problem... just replaced the spool valve it's a little better but the load drift is 12" every 5 mins... I think there may be a check valve I over looked. Does anyone have access to a manual or hydraulic print?
  • Posted 21 Jun 2012 00:18
  • By jaslyman
  • joined 6 Jun'08 - 28 messages
  • Virginia, United States
I need to kknow what type of lift cylinder you have. Can you send a picture to my e-mail?
  • Posted 11 Jun 2012 23:35
  • By bbforks
my c500 is a single lift cyylinder with two tilt cylinders, one control valve with two levers.
any help
thanks
  • Posted 11 Jun 2012 22:53
  • By khans
What kind of upright is on the machine? Could be either a faulty hydraulilc control valve or packings in the hoist cyl. The symtoms will be different depending on the upright cylinder.
  • Posted 9 Jun 2012 06:58
  • By bbforks
If I lift the mast anywhere ohter than all the way to the top, then I release lift the forks they fall to floor, 10 seconds per 10 foot.
If I hold on lift they fall slower. my question is is there a check valve or a bad cylinder.
thanks Ken
  • Posted 9 Jun 2012 06:05
  • By khans
Don't understand your question- you'll have to make it clearer what you want to know
  • Posted 9 Jun 2012 03:07
  • By bbforks
Taylor TE650S
UN Forklift FD50T-NJB3
October 8-10, 2025 - Lucca, Italy
June 17-20, 2026 - Bangkok Thailand, Thailand
August 19-21, 2026 - Bangkok Thailand, Thailand
Funerals in Spain typically occur within 24 to 48 hours of death, whereas in other European countries they wait one or more weeks. This rapid timeframe is a cultural norm grown from the past need to manage the warm climate without modern embalming.
edition #1250 - 2 October 2025
Rob Ott Rob Ott
Executive vice president and chief commercial officer, East Penn Manufacturing
President, Logistics UK
Director of dealer development East Coast, Big Joe Forklifts
Vice president, customer, TVH Americas
