BT / TOYOTA LWE 200
Need help if possible,
We have a fault code C28 displayed, checked emergency stop ets all seems ok.
Can anyone supply me with a service manual or wiring diagram for this truck.
I would prefer service manual if possible.
Thanks all
  • Posted 1 Jun 2012 23:15
  • By micky_h
  • joined 26 May'11 - 205 messages
  • South Elmsall, United Kingdom
yes, you are right Rogeriwt.
When this happens, the PTC resistence overheats so pin16 in transistor controller does not receive 24v.
It's easy to check, if touch PTC it's too hot. (BE CAREFUL CAN BURN).
Regards
  • Posted 2 Jun 2012 22:15
  • By nacsand_n
  • joined 20 Sep'09 - 716 messages
  • Madrid, Spain
I have also had this code when the lift pump motor contactor sticks.
  • Posted 2 Jun 2012 09:38
  • By rogeriwt
Hi Micky,
If have been checked the emergency stop, first check PTC resistor connected in main contactor (K10) terminals.
If resistor is OK, check voltage on pin 16 (wire n24) of curtis transistor regulator should be 24v
iIf the above is correct, check battery, this failure is also produced as a result of a defective battery.
Check your mail.
Regards
  • Posted 2 Jun 2012 06:54
  • By nacsand_n
  • Madrid, Spain
Muncie, IN, United States
Terberg RT223
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Deborah Baker Deborah Baker
Terberg RT223
USD1
