Error Codes
Is there a list with the error codes for a 2ET3000-AC Jungheinrich Electric Fork lift? I have a unit that's giving me error codes 3202 and 0181. Any help that you can provide will be greatly appreciated.
  • Posted 31 May 2012 00:07
  • Modified 31 May 2012 00:07 by poster
  • By Slickster
  • joined 31 May'12 - 1 message
HI! On jungheinrich EJE225 I have code 303 and 2308 Can you help me on that please???
  • Posted 4 Jul 2017 04:52
  • By Martin2000
  • joined 25 Oct'11 - 30 messages
  • Quebec, Canada
hi can anyone know what is the problem of EFG216 jungheinrich forklift
Message:alarm 39,alarm 81..thank you..
  • Posted 4 Apr 2017 02:29
  • By Jorne
  • joined 2 Dec'16 - 27 messages
  • Jebel ali dubai, United Arab Emirates
I have the same problem but my first code is 2307. does anyone know what it is and i have the same 0181 after.
  • Posted 16 Mar 2017 03:42
  • By yansolo
  • joined 27 Sep'12 - 8 messages
Hi i have problem with EFG 215 ERROR CODE 3317 AND 0181 PLEASE HELP E
  • Posted 20 Jan 2017 21:52
  • By ajay_k
  • joined 23 Apr'16 - 4 messages
  • Maharashtra, India
Hi, you have a probleme with steering sensor. good luck.
  • Posted 29 Aug 2013 05:23
  • Modified 29 Aug 2013 05:24 by poster
  • By zakaria
  • joined 29 Aug'13 - 5 messages
  • casablanca, Morocco
I have problem with EFG320. There is two erroe codes: 111 and 027. Can you help?
  • Posted 27 Aug 2013 18:18
  • By adam_b
  • joined 27 Aug'13 - 2 messages
  • Bielsko, Poland
  • By adam_b
  • Bielsko, Poland
There is a list but it is avalible in the Jeti and Judit software. Unless you have access to the software you are out of luck. Dealers will not give up this information. Your codes are a four part message. The first digit is a function group, the second is the event group, the third is the code and the fourth is the sub index. ( you need the software to read the sub index). Example, 0181 is a (fuction) 0= overlapping function (event group) 1 = general fault ( event #) 81= Self test fault. You can not read your sub index unless you hook up Judit. Your 3202 code is broken down like this. (function) 3= Steering, (event group) 2 = current problem, (event #) 02= Power connection is too high. Again you will be unable to read you sub index without the software. You fix your 3202 code your 0181 will probably go away. Look for a shorted steering motor, contoller or a shorted power cable. Good luck with this one. Hope you have the software.
  • Posted 29 Jun 2012 01:26
  • By mfctech
  • joined 20 Jan'12 - 7 messages
