TCM FTB 16-7 - Reverse lights and buzzer on all the time ?
Can anyone please direct me to a fix for this machine - all works well except reverse lights and reverse buzzer are on all the time - even when you disconnect direction lever. Any help would be appreciated. Thanks.
  • Posted 25 May 2012 23:00
  • By Reddog
  • joined 23 Feb'09 - 58 messages
  • Wrexham, United Kingdom
Yes i have in mu profile you have my mail, contact me on him please.
  • Posted 29 May 2012 05:40
  • By nemanja_k
  • serbia, Serbia
thanks very much we will be going over on Wednesday and hopefully sort out what is needed - do you have a part number for the fet (s) please ?
  • Posted 29 May 2012 01:21
  • By Reddog
you will be able to change fet, if everything is ok on board diode and linear ic your board will work.One advice use original fet because some works different and than you think that problem is somewhere else. Fet that you need to look is fet6,fet7 and fet8.
Good luck
  • Posted 29 May 2012 01:03
  • By nemanja_k
  • serbia, Serbia
Thank you so much for the help, Do you have a part number for the board or will i be able to replace one of the fet transistors only. ?
  • Posted 28 May 2012 17:09
  • By Reddog
you need to open right side and fix small electronic board for lights on her you have six or seven fet transistors work like switches.Mail me if you need and good luck
  • Posted 26 May 2012 07:00
  • By nemanja_k
  • serbia, Serbia
Muncie, IN, United States
Zhejiang UN Forklift Co., Ltd
Deborah Baker Deborah Baker
