Hyster S135XL2
4.3L wont fire after shut off hot until 30 minutes later. I followed schematic, and discovered a start/run relay in the circuit not listed. Once key is turned to crank, relay pulls in, but wont release, and it's not a sticking relay. If i physically open the contacts on the relay after cranking, it will start everytime. Does anybody have any info on this system? The relay sits behind the battery, and I already changed it out with no luck.
This is an Lp only system using a HEI module as well as an MSTS controller. Any help is appreciated
  • Posted 10 May 2012 11:29
  • By Tryinlinux
  • joined 10 May'12 - 8 messages
Only one schematic on that truck shows the relay. One wire goes to a three wire chassis plug but I cannot find anything else on that plug in any of the schematics. The wire colors and relay positions and connections are, White wire, pos 30, from starter solenoid, lt blue and pink,87a, starter lockout,12 volts when cranking,pink and tan, pos 86,comes from fuse. It could be the ign switch holding power on the relay for the time frame, or could be the start side holding power. Hope that helps some.
  • Posted 10 May 2012 12:29
  • By meliftman
  • joined 31 Jan'12 - 209 messages
  • Alabama, United States
Liftman
Retired
Elberta, Al.
UN Forklift FD35T-C2JB2
Manitou MH25-4
GemOne
GemOne
Manitou MH25-4
Muncie, IN, United States
